need help with check eng light
6.5K views 5 replies 5 participants last post by  MonsoonMike
Have a 2015 4x4 CC Crew cab, 6.7 engine. Have C1400 check light and cannot find out any info on it. What is it and can I drive the truck until Monday when dealer opens.
TIA
#5 ·
C-Codes
01 Airbag warning indicator output circuit shorted. Refer to the appropriate
diagnostic information.
02 Airbag warning indicator output circuit open. Refer to the appropriate
03 ABS indicator output circuit shorted. Refer to the appropriate diagnostic
information.
04 ABS indicator output circuit open. Refer to the appropriate diagnostic
information.
05 MIL indicator output circuit shorted. Refer to the appropriate diagnostic
information.
06 MIL indicator output circuit open. Refer to the appropriate diagnostic
information.
07 Wait to start indicator circuit shorted. Refer to the appropriate
08 Wait to start indicator circuit open. Refer to the appropriate diagnostic
information.
0B BTSI output circuit shorted or open. Refer to the appropriate diagnostic
information.
14 Fold Down Tow Mirrors
22 Headlamp switch input circuit shorted. Refer to the appropriate
23 Headlamp switch input circuit open. Refer to the appropriate diagnostic
information.
24 Turn hazard switch input circuit shorted. Refer to the appropriate
25 Turn hazard swiitch inpot circuit open. Refer to the appropriate
27 Courtesy/dome output circuit shorted or open. Refer to the appropriate
28 Glovebox/map lamp output circuit shorted or
open.
Refer to the appropriate diagnostic information.
29 Cargolamp output circuit shorted or open. Refer to the appropriate
40 Wiper switch input circuit shorted. Refer to the appropriate diagnostic
information.
41 Wiper switch input circuit open. Refer to the appropriate diagnostic
information.
42 Wash/beam input circuit shorted. Refer to the appropriate diagnostic
information.
60 Passenger door lock switch input circuit
shorted.
61 Passenger door lock switch input circuit open. Refer to the appropriate
62 Passenger door lock switch input circuit stuck. Refer to the appropriate
63 Driver door lock switch input circuit shorted. Refer to the appropriate
64 Driver door lock switch input circuit open. Refer to the appropriate
65 Driver door lock switch input circuit stuck. Refer to the appropriate
66 All door lock output circuit shorted to ground
or voltage.
67 All door unlock output circuit shorted to
ground or voltage.
68 Driver door unlock output circuit shorted to
ground or voltage.
6C Driver cylinder lock switch input circuit
shorted.
6E Driver cylinder lock switch input circuit stuck. Refer to the appropriate
80 Incorrect odometer value found. Refer to the appropriate diagnostic
information.
81 Remote radio switch input circuit high. Refer to the appropriate
82 Remote radio switch stuck. Refer to the appropriate diagnostic
information.
A0 Internal module FLASH memory checksum
failure.
A1 Internal module bootloader failure. Refer to the appropriate diagnostic
information.
A3 Battery voltage open. Refer to the appropriate diagnostic information.
A5 TCCM messages not received. Refer to the appropriate diagnostic
information.
A7 VIN checksum error. Refer to the appropriate diagnostic information.
A8 VIN previously stored. Refer to the appropriate diagnostic information.
A9 PCI bus internal failure. Refer to the appropriate diagnostic
information.
AA PCM messages not received. Refer to the appropriate diagnostic
information.
AB TCM messages not received. Refer to the appropriate diagnostic
information.
AC ABS messages not received. Refer to the appropriate diagnostic
information.
AD FCM messages not received. Refer to the appropriate diagnostic
information.
AE ACM messages not received. Refer to the appropriate diagnostic
information.
AF SKIM messages not received. Refer to the appropriate diagnostic
information.
B0 RKE fob batteries low. Refer to the appropriate diagnostic information.
B1 RKE module communication link. Refer to the appropriate diagnostic
information.
00 Done All Diagnostic Trouble Codes (DTC) have been
displayed.
wait for it...
