Dont purchase even a simple washer from ATS. Just dont do it. Everything they make is complete garbage. The firepunk anteater is the preferred controller.
With that kind of weight, I personally would be hesitant to run a lockup switch on anything but a FMVB. You simply cant get the control you want with a computer. Other than maybe stock programming which isnt adjustable and short shifts like its going out of style.
But it's like I've seen so many times before.. People running stock output shafts doing 15psi 4wd launches many many times and it takes a long time for the shaft to let go. Some people get away with murder, me, I cant get away with anything. I would break a fat input doing a 5psi launch at stock power with how things usually go for me.
Like I said, with that weight and upgrades, I would be hesitant to run a switch, but if you are smart about it, it could work very well.
Sent from my SM-N950U using Tapatalk
