I have hear this expression many times and understand it to mean, " getting the turbo to start building boost".
Beyond that simple answer what is actually happening?
Is heat a factor, or would the turbo spool equally well if compressed air of ambient temperature was pump in?
Is the goal of lighting the turbo a matter of getting the cylinder pressure as high as possible before boost actually happens, through providing only the fuel the non boosted engine can actually burn?
Is fuel actually being burned in the exhaust driven section of the turbo? As it would in jet engine?
I am sure many of you guru's know, but if I have this question I am sure many others are un clear as well.
