Hello Everyone,
I started installing my KDP kit from BD Performance and have a few questions.
What is the dowel pin used for that comes in the kit?
Front seal service kit that was provided is 3904353. I did not find a dust shield provided with this kit. Is there suppose to be one? Do I have the wrong front seal?
The front seal service kit part number I found online is 3804899. Is this the right one?
The alignment tool to install the front cover onto the engine is a semi-clear stepped piece of plastic that allows the seal to slip over the crank without damaging the lip.
Are you supposed to install the alignment tool so that it will be trapped between the engine and timing cover? When you seat the timing cover to the engine, how do you remove the alignment tool?
Please let me know! Thanks.
