A high idle kit is a good idea, just gives a higher oil pressure and keeps teh motor better lubed.
However, if it were winter, I would advise against it, sometimes these 24 valves can actually get carbon build up on the valves, the valves can stick and actually bend pushrods, so the only way you should do it in the winter is if it's plugged in or at a high idle. Even when the truck is fully warmed up, the cold air coming through the turbo at idle can cause the valve to stick, I learned that with my truck and letting it idle after I was done plowing.
