Installing a Heater Core Shut Off Valve D250
14K views 14 replies 6 participants last post by  9297oldram
I've been searching for a good thread on installing a shut off valve at the heater hose to help with the A/C temp. I've seen some for newer models but need something with a step by step for our first gens.
Does anybody have a link they can share?
Thanks.
#2 ·
Any standard ball valve will work. Get a 5/8" (iirc) brass ball valve in place of your heater valve. Keep it closed in summer and open in winter.
#3 ·
Does it go on the passenger side or driver side hose?
It's just another acronym for If I Remember Correctly. And I agree, remove the vaccuum operated one and put in a brass ball valve.
#7 ·
#8 ·
I ended up using a 3/4 valve with some clamps and it worked out just fine. Now for the big test tomorrow to see if it helps out the A/C!
Once again thanks for the help.
#9 ·
Here's the set-up I put on my truck....
I searched high and low for the "right" manual shut off valves I wanted to use. Many hours were spent searching all over the internet until I happened across these babies!
4 Seasons 84706. Used on early 70's dodge pick up trucks.
And the vacuum operated shut off valve was not available for our trucks...at least with a 5/8 x 5/8 hose connections. Maybe I just couldn't find it, but I searched high and low and never could find a direct OEM style replacement.
I found many that would "work" but looked hideous, IMO, but eventually found one I liked.
4 Seasons 74859. Used mainly on Ford Rangers from 2003 to 2008.
Now here it is all installed...
Now next summer I can just turn off the valves and no heat, or coolant will enter the heater core to affect my AC temps.
#10 ·
This is the first time I see two installed. I only put one on the passenger side hose. How necessary is the second one?
Nice set up by the way.
#11 ·
Not necessary to have the second one on there. I just did it so that there would be virtually no heated water entering the heater box. Even in the stock configuration, just the shut off valve on the in-flow line, the out flow still transfers heat into the heater box through convection. ;)
#13 ·
Thrashing- makes sense. I think I'll add a secondary. It's easy enough and any little bit helps.
Gilbert- that's the one I ended up using. Works perfect. Glad you posted that pic for the people to follow.
#14 ·
I want to bypass my heater core in my repowered van. I keep reading its ok to stop the flow from the head without fear of hot spots, but then some people still building a recirculation pipe to continue flow..
I cant find info on testing engine temperatures with the coolant port on the head next to #1 blocked.
Has anyone actually tested that, so I can be sure I don't need a recirculation bypass and simply install one valve?
Thanks
