Got a question for the professionals. How long does it take to remove an auto and replace the input shaft? I want to get a billet installed.
so you think the 2 piece is stronger then a 1 piece???The one piece shafts are a compromise in my opinion. OEM uses 2 piece design and so should you. if your gonna spend 600 to save your shorts, go the distance and spend a little more to get the Good Stuff.
This is why:thumbsup This is just two of Two different transmissions with the 300 mirage shafts so look at the shaft splines and the brooken shaft and you tell me why then. What other proff do you need? Call DTT and Dave for more:thumbsupOK Charlie.
I don't run Opie Shafts either, but you assumed I was speaking of them. You talk the talk all you want, but tell me something other than I have references and all these know it alls use them. That would be doing the thread justice.
You are peeing in the thread, not me. I offered my opinion and tried to back it up with my reasoning, you are looking for an opportunity to dominate someone, and talk trash with no supporting info.
How bout some facts. Why Not Support the thread?
I'm not gonna argue with you either, so why don't you take a breath and tell us why the Single piece 300M shaft is better than a 2 piece shaft made with 300 mirage and a 4140 Gear.
