how many transfer cases in 1990 model year?
1 reading
20K views 24 replies 8 participants last post by  geddy's uncle
Son and I are heavy-dutying his 1990 Ramcharger (made in Mexico, if it matters).
We've ordered a Dana 60 (3.55's) to replace the D-44 that's currently under there.
A matching Dana 60 or 70 rear will be much easier to source than the 60 was, so we should have an easier time proceeding.
The 360 V8/4spd auto is going to come out, in favor of a B-block and NVG 4500, once we've got the axles swapped and any related bugs worked out.
Were there a variety of transfer-cases, or did Dodge go "one-size-fits-all"?
Also, now that it's a little late to ask, was there any frame-rail-width difference between the W-150, W-250 and W-350?
#2 ·
The diesels had a 23 spline input shaft for the autos and a 29 spline shaft for the getrags. Both models were NP 205's.
#3 ·
OK, that's a good thing to know...Leads me into another question, though.
Easier to find a pre-matched and mated engine/tranny/t-case, or easier to change the input shaft on the existing T-case? I presume I'm gonna need the "4WD" tranny anyway, in order to get the tailshaft tunnel that attaches to the face of the T-case, anyway, right?
in order that I don't miss something important... did ALL the W-series use the NP 205's, or just the 250/350's or just the Diesels? remember, a Ramcharger's essentially a W-150 station-wagon...
#5 ·
It will be easier to get a matched set. If your going with a gasser engine ( like you said ) I am not sure what they came with. I just gave you the diesel options. I think the later gassers had an aluminum case transfer. If your going with a 440 I would look for an older set up that was behind a big block and I would assume those would also have the better cast iron gear to gear np 205. I never messed with any gasser dodge's so Im over my head with those. ( I was a chevy gasser guy before a diesel idiot )
The 205s only came in the diesels unless they were a special order. All the the others were the 208 aluminum case. Most transfer cases behind the 727 and np435 in the gasers had the same spline count from the 74-93. I have run the 208s behind big blocks for years and they do break. I would suggest finding a 205. Or a 203 and do a part time change over kit into it. The only thing have to worry about those is stretching the chain but it takes alot abuse to do it.
#11 ·
OK,...Well, when this project's in the progress zone, we'll have an EFI 5.9L for sale, matched w/its 4spd auto (727?) and the "gasser" t-case and axles for sale.
In their places will be either a 1st or 2nd-gen Cummins/NVG 4500/NP205 and Dana 60's.
I'm glad to know the frame-rail width is the same, so that the axle-hanging geometry will not have to change. :)
Gonna be a big project, hopefully pegging the "cool-o-meter", and resulting in a 50-year truck.
#12 ·
OK, I just re-read some of the posts: Raises a question. Any special considerations if we get a 1st-gen "B", and a NVG 4500? For under-hood geography, the non-intercooled version would be easier, but, if it would make life difficult under the floorpan, that's not a good tradeoff, and I'd be better off with a P-pumped/cooled 94+....but, then, I still need a T-case that matches a passenger-side-pumpkin front-axle.
So, here's my intention so far:
B...NV4500...NP205/passenger side front...For that, would I be stuck with a Getrag, and an "old" 205, or can a "new" tranny and an "old" T-case end up pointing the right direction?
#13 ·
A 29 spline transfer case from a getrag set up will work with a NV4500 diesel tranny. My 92 has the NV4500/205 set up.
#14 ·
The getrag 205 will fit and Dodge diesel stick trans used to current year. They all use the 29 spline output shaft. The mounting is the round 6 bolt configuration.
If you notice my signature. I have a G56 6spd in my truck. It came out of a 2007. The 205 bolted right up. No problems.
#16 ·
a guy I found on ebay has 4500's mated to 205's, and with a variety of bell housings.
gonna order his whole setup. might seem a little pricey, but, he offers a bit of warranty, AND they arrive as a unit, already disassembled/cleaned/inspected and reassembled
not a bad deal that way
#19 ·
94+ models came with 241 Tcases. Those are a driver side drop case. The 1st gen 205's are a passenger side drop case.
#21 ·
No it isn't. All 94+ models were driver side drop with 241's and higher Tcase model numbers.
93 was the last year for the 205's in the Dodge line up.
#22 ·
that big-assed heavy chunk o'iron is on the way, as are the matched d-60 axles (rear has already been disc-converted, too!)
found a clutch-pedal/brake-pedal set on ebay
now, just need clutch, engine/flywheel, and the various small incidental parts needed for the proper function of the major components....
progress, progress, progress.....might have'er up and running within the next couple of months :)
#25 ·
I have to assume that the bellhousing is the one from New Venture, and not one that's "Dodge" or "Cummins" designed.
Here's the update, though:
Engine arrived @ Coastal Diesel a couple of weeks ago, when cumminsforum member Mark Nixon dropped it off. In the meantime, I've received a SouthBend 400HP/800TQ clutch, and the matching 13" flywheel, and also a pack of 3/4T springs for the front end.
The shop's got all the major components, now, for the buildup.
Axles.....check
tranny/t-case....check
engine.....check
clutch.....check
front leaves for the bigger weight....check
the truck itself.....check.
replacement pedal-set for the firewall....check
They'll be able to identify and source the final-fitment specifics, like clutch housing/bellhousing adapter, longer U-bolts for the spring-axle mounting
they've got bright shiny tools, floorspace and time.......and a way to write up a bill :eek:
