How does EFI live work?
1 reading
38K views 37 replies 18 participants last post by  MegaB
Please forgive the dumb questions but I have no idea how EFI live works.
Is it like a programmer with base programs loaded or does it have to be programmed for each truck?
I guess what I am asking is if I purchase a 06-07 Dodge 2500 and order EFI live how will that work?
#3 ·
EFILive is just a software that takes the ECM parameters and enables "you" or a "tuner"(person that manipulates the parameters) to change them and flash them back into the ECM.
EFILive does not build performance tunes or even tune them selfs. The only provide the software.
You have two choices with EFI, you can purchase either a V2 or autocal. The difference between the two is with the V2 you have the ability to write your own tunes or purchase tunes from any tuner you choose. The autocal is cheaper but is linked to a particular tuner. The function of both is similar in that you can datalog and check & clear trouble codes and such, may be more the V2 can do but I went with an autocal so I'm not too familiar with it.
Basically you will get the device and read out the trucks stock file and send it to the tuner you choose with what hard parts you have on the truck and what your looking for performance wise. They will then write a tune or number of tunes(tow,street,race,etc.) and email them to you and you install it to the device then load it on your truck like you would any other programmer. You run it see how you like it, maybe datalog a bit and if you need changes you can send your tuner the data logs and they can adjust. It really is the only way to go for 06-09 trucks.
Hope this helps
Reactions: Bk1911 and Blazer
#5 ·
So you buy the device and then pay someone for the program to load into your truck,....the device is simple a gateway to your ecm?
I guess this means EFI live is only as good as the person who writes the files? I would think this needs to be done while the tuner has your truck on the dyno?
#8 ·
X2^^^^^^ what cr said. There are a number of reputable tuners out there, Anarchy, Silverbullet, Innovative to name a few.:thumbsup:
#10 ·
I have tunes from 2 of the 3 tuners in this thread. Not disappointed in either.
#12 ·
I'm one of those who bought the autocal, only to buy the V2 later. I didn't do my homework but when I got it I also thought I'd stick with only one tuner. I'd recommend getting the V2 right off the bat. There are some very well known, very good, tuners out there. Some of which, posted in this thread :thumbsup:
Sent from AutoGuide.com App
#13 ·
I bought autocal, was super happy with my guy, wrecked my truck, bought a new license for new truck from him, and then he split on me. So, the lesson I learned is is this: keep your options open and buy a V2.
#14 ·
Efi all the way over a "box tune" just switched from a smarty to efi. Allot smoother power and def not as smokey. Almost smoke free which is awsome after 4 years of smarty smoke. I got autocal figured let the guys who know what there doing do there job. I couldn't be happier with who I choosed. Do your research and you will be fine.
#31 ·
So you pay a diesel witch to possess your truck and said witch whispers go fast codes to the computer? I think I got it now
Reactions: JohnCTD and GLBWAMR
#33 ·
After switching from the smarty to EFI Live and feeling the deference of Phil's Anarchy tune, I guess we should call him Phil "The Cummins Whisperer"...Wait, that could be interpreted bad.
#34 ·
Yea I think that may be borderline porno name lol
#36 ·
Forgive me for my ignorance here but how exactly is the anarchy autocal level 1 different from say a smarty jr etc
