It seems we are getting one thing fixed just in time for another thing to let go. Or we are on a continuous journey to find and fix a noise or a problem. I say lets list the problems and their status. I feel it will be a way to vent and laugh at all of our problems. This should include everything we have already fixed.
1-front end warping sound. Aligned axle with adj. C.A.'s,
Lucas Oil in the pumpkin, STILL UNFIXED!
2-front end wander- new trac bar and some other bar also, new steer. stablizer. STILL UNFIXED!
3-worn ball joints- put new ball joints in and my tires still leaned inward. Had to take everything back apart and get the Moog adjustable ball joints. FINALLY FIXED!
4-steering is difficult when not moving- New steering gear, adjusted steering gear. STILL UNFIXED!
5-Front tires too close to rear of fender, not center.- Put on some super tough adjustable CA's from Dunks Perf. and moved it forward. FIXED!
6-Cracked dash-No attempts to fix yet.
7-lighter just pulled out of dash- no attempts to fix yet.
8-LP failure- relocated with stock and new psi gauge, gauge saved me warrantied LP and added a pro comp. FINALLY FIXED! @ 20psi now
9-Broken transfercase chain and case- why would Dodge put a t-case that has a capacity that is less than what the truck weighs? STILL UNFIXED!
10-super fast 2-3 shift-adjusted bands-FIXED
11-OD won't shift @ WOT- adjusted TV cable- STILL UNFIXED.
12-tranny started slipping-drained all fluid, blew all fluid out of lines and put in 11 quarts of atf 4 and 1 lucas. Did not fix. Cleaned all grounds and that was it. FIXED!
13-leaking driverside axel oil seal-STILL UNFIXED!
14-sticky release on hood latch. FIXED after my hood flew up and bent my hood latches because the release was stuck up.
15- VP44 died 148 miles away on a friday evening! After hotel room, rental car to drive home the next day and then the drive back and then home again total of 2400 bucks later it's... FIXED!
16- Alignment- after 3 different shops aligning it is at least bearable. SOMEWHAT FIXED!
17-driverside seat adjuster bar broken- STILL UNFIXED!
18- Oh, I am waiting for #18! 18 showed up! speed sensor went out so I replaced it.
I forgot a few so I am adding to my BOOK!
19-clock spring went out-FIXED
20-fuel sending unit went out-FIXED
21-return line check valve went out, not knowing it at the time I almost had a new VP put in. Good thing my dad found it was leaking.- FIXED
22- I am now waiting or trying to remember #22.... Oh Yey!
