Hope 3rd Time Is A Charm
1.8K views 16 replies 7 participants last post by  DieselRig
So I have had a diesel of the other two makes. Hoping the third one is a charm and I will love the Cummins. i'm looking for a 3rd gen CR to start my adventure...not sure of which year is the best because I grew up around 12v's and a few 24v's as that's all my uncle would drive lol...had a 2500HD CCLB 4x4 Duramax and hated the IFS/a couple of other complaints but a decent truck overall...then came a 2008 F-350 CCDRW 6.4 4x4 fully loaded Lariat...TERRIBLE fuel mileage like unacceptably bad after being tuned and deleted and am now looking towards Cummins. I know they get great mileage comparable to the other two and seem to last forever. Help me decide which year is best for me...Looking for something under $24k, has to be 4wd, has to be a 4 door and I would prefer a manual but I could live with an auto....not too picky about mileage just under say 200k thanks in advance sorry for the long post
#2 ·
03-04 cr get good mpg
04.5-07 HO 610lbs tq, get a lil bit more power but mpg's go down a bit
07.5-11 6.7 650lbs tq, have the newer federal emissions
11.5- now 800lbs of monster torque stock
As with all dodges, the automatics are the weak spots especially when tuned. The 6.7's have a better 6sp automatic and an exhaust brake and VGT. If you go with an auto, id go for the 6.7, manual is good in any year.
The 6.7s won't get any mileage till you delete them. And deleted, head studs are an immediate recommendation cause they are popping head gaskets fairly easily.
With a 5.9, injector life is about 150k mi. Anything over that is a bonus. Some have gone as quick as 125k ish and others have lasted well over 200k, but most of them are on a second set by 200k. It's $3k for a new set.
A built auto behind a 5.9 is hard to beat, but it's about $7000 to build it for 600-700hp. Manuals are far a few in between.
#8 ·
Glad I found this thread. I'm in the same boat. I've found what I want 2005 2500 4x4 quad cab, 6-spd 8' bed.
My only concern is injectors. Do the '05's have problems after you replace the injectors? and if I put on a 2micron filter should I expect the 2nd injectors to last?
#9 ·
Rocket- You should absolutely expect injectors to last if you are running a 2 micron filter set up and good fuel. Im not sure why my first set went bad so quickly because I have only owned the truck since 57k miles. My guess would be a pressure box. Goodluck
#11 ·
Rocket- There are a number of symptoms the truck may suffer from when the injectors are failing/bad. Most common issues is the truck will begin to "make" oil. An injector(s) may leak or be stuck open and cause fuel to seep past the rings and accumulate in the oil. Next, the truck may smoke/haze white or grey upon start up. My truck had both of these symptoms when the injector(s) failed. I never had them tested so I do not know if one or all were at fault.
When buying a truck drive it, ask for service records, ect. If you are driving it at night and it hazes heavy that could also be a symptom of bad injector(s). If you catch these symptons quickly and do not let them go you can expect to solve the problem with new injectors, if not they could lead to major engine failures in short time.
#13 ·
Any type of diagnosis as to why the injectors fail? I saw you put something about a pressure box...what about if the vehicle is tuned with just a tuner instead of a pressure box or left stock? Still major injector issues? Just asking because coming from a Duramax I know all about LB7 injector problems and don't want to end up like they do
#14 ·
I wouldn't necessarily call it a problem. They just don't have as long of a lifespan as the 2nd gen trucks. Your asking something to hold an avg. 18,000 psi, and fire 2500 times per minute for the life of the truck (these trucks have 3 injection events every combustion stroke). at 100k mi the injectors have fired at least 2.8 BILLION times if the truck was on the road its whole life and spend no time in the city.
Now dirty fuel can cause them to hang open and dump fuel into a cylinder, typically causing a failure and added filtration can help prevent that. Or a pressure box will stress the seals and its ability to close and cause premature failure. If the tuner didn't hop the rail pressure up your probably ok... but if it had a tuner on it, it probably wasn't handled with great care so inspect it carefully
RoadMedic on here is at 700k+ mi and just installed his 3rd set of injectors.
#15 ·
I've heard of lots of trucks that haven't changed injectors once past 150k. I owned one. That truck has 220k on it now and is still running on stockers. Lucky I guess! It was an 03 HO I know the spray pattern was different among other things. I know of this other truck that has been a highway truck its whole life, and ran a fuel additive in every tank of fuel. That one is running past 160k now on stockers.
Then again, I've heard of many more that have changed injectors :banghead:
#17 ·
Ive never had to change injectors but yes they eventually need to be replaced. One thread to look at is about the injector #4 line. Appartently is was a engineering mishap and they rattle loose, come off, etc. Never had that problem either but very common as well.
