Not really, except more wear and tear on your starter and batteries. If you're concerned about the diagram, dont be. Its very easy and the diagram makes it look far more complex than it is. You just go down to your local parts store or electrical store and ask for a 5 pin relay that has the exact pattern show in the little box in the diagram. Then wire it as shown. The only wire you have to touch thats already existing is the yellow wire which is the fuel pump power wire. The relay splits that wire. The rest of the wires are just running to a source or tapping into.
Also, just for knowledge, there is another factor which can cause this hard hot start. The ISB is fully electronically controlled. Because of this any improper voltage or amperage will cause weird problems which will have you chasing your tail looking for the reason. The most common place for this to be an issue is your batteries. If one of the two is not perfect then it will go undetected unless you unhook both batteries from each other and the truck and load test them. You may find one of them has a bad cell but together they still start and run the truck. Bad batteries are trouble.
The other place to look is all major electrical connections and grounds (including battery and battery cables). Make sure any and all connections on the engine are tight and not corroded. This can more of a problem in high corrosive areas where they treat the roads with salt or calcium chloride.
Saying all this, I'm sure its still your fuel pump. Try unhooking that fuse like I said and see what happens.:thumbsup:
