A few days ago I purchased a 2014 Ram 3500 Laramie Crew Long Bed 4x4 to pull my 40' fifth wheel. The truck is really nice and is maximum steel with grey accent color. Anyway, should the tire pressures be set at what the door jam sticker says which is 80lbs front and 65lbs rear? I read somewhere that the inner tires should be a few pounds less. Any truth? What is a good tire gauge to check the inner tires pressure? The truck has the Alcoa polished wheels. Advise on how to keep them looking good would be appreciated. I ordered a 80 gallon in bed aux fuel tank since the truck only has a 32 gallon tank. I am having it sprayed with bed liner material since the truck came with the factory sprayed in bed liner. Aux fuel tank is made by ATTA. Any suggestion on does/don't with this truck? Thanks in advance.
