EZ Lynk questions
22K views 17 replies 9 participants last post by  CHoquette
Does the EZ Lynk come with installed tunes for stock and deleted? If so which version do I need?
As of now truck is stock. 2014 2500 4x4 w/68RFE.
Would I need to buy another tune if I decide to delete down the road?
Also if I decide to change the trans valve body, is that a separate tune?
#2 ·
Pretty sure the EZ lynk is like EFI live where your tunes depend on which custom tuner you go with.
From what I have taken from it and I would like to know myself if this is how it works, you pay to play so to speak. Then you get full access to the "cloud" that has all kinds of different tunes offered by your tuner that you in turn download and install onto your truck via your mobile device.
If that includes emission tuning and delete tuning, that would be a pretty sweet deal.
A valve body would allow you to up the line pressure which I would assume require a custom file.
#8 ·
Sounds like there are multiple tuners offering emissions and non-emmsions (offroad/race) tunes. I just got an EZ lynk from Starlite diesel and they uploaded both for me with my purchase of their SOTF tune set. They also included TCM tunes and non TCM tunes to boot.
Sent from my SAMSUNG-SM-G890A using Tapatalk
#10 ·
can you just use the Ez-lynk to change the tire size without unlocking? I will be deleting but I'm waiting a bit longer before I bite the bullet and loose my warranty. If I could buy it now to change the tire size and use it for monitoring for now it would be great for me!
Thanks
#11 ·
Yep PPEI does. Very good tunes also. I don't really know if you can monitor things with out the tuning but i don't see why you couldn't. Id say call a dealer and ask before you spend the money.
#14 ·
So I don't need to unlock the ECM to do that? I won't loose my warranty? Thanks
#16 ·
and when you will want to unlock the ecm you'll just need to buy the tune package from a tuner and that's it?
#18 ·
Well I pulled the trigger I did like you! I bought only the auto agent and I will be buying the rest later down the road! Thank you for all your help
