External voltage regulator help!
3.3K views 6 replies 3 participants last post by  gasjr4wd
2006 dodge 2500 5.9l cummins ho stopped charging all of a sudden. So I replaced both batteries and replaced the alternator and it still wouldnt charge!
My mechanic ran a few test and said the truck needed a new ECU. The part was a week away and 2300$ so i read online you can install an external voltage regulator.
Once installed the truck was charging again but its now over charging at 16-18volts!
Any of you guys have this happen and what did you do?
Thank you
Cmo
#3 ·
Well on the volt gauge its maxed out, and the truck will act weird. If the fan speed is on 4 the gauge cluster works if its shut off the gauge cluster doesnt work.
All the post about external regulators were for older trucks. Will the external regulator work on a 2006?
#5 ·
I just got my pickup so I'm not sure about if I have an external reg. I just meant that mine seems higher than I would think normal. I noticed about a week ago when I would turn the lights on the voltage would drop way down and then shoot back to normal. It would do this for a bit and then go back to normal and stay there. I tightened the cables a little and it seemed to fix the problem for now
#7 ·
Before you go any farther-
Make sure your cables are in perfect shape... mainly the crossover cable. What side was tested? These things read one side but charge the other. Gives all sorts of goofy issues if your cables aren't in tip-top shape. Many times they go bad under the sheathing.
Common issue. Look it up.
Electrical system works well as designed. No need for additional external reg.
And to goldie88: working fine: grid heaters.
