Exhaust cut out instead of DPF delete?
1 reading
14K views 11 replies 5 participants last post by  Mopard
Here's a crazy idea, what about instead of doing a DPF/CAT delete changing the down pipe, installing a Y-pipe with a 12volt cut out. You could just push a button and have free flow exhaust keeping the DPF/cat so you can pass emissions.
Just wondering because the hot rodders have been putting them in for years.
#2 ·
You would still need the tuner, but it is feasible, unless the look under your truck.
#5 ·
:hehe: that's why I was saying hook up a Y-pipe, so it'd be a dual exhaust, and when I go for emissions I just tell the guy it's hooked up that way for when I go to the track.
We only have to do emissions every two years so, I'll see how tough it is to get a inspection done.
Here's a look at the part, I haven't been able to find anything bigger then 3" other wise I would have done this instead of a delete.
My buddy was telling me to do it this way, so I wouldn't have to get a dirty e-test. I was in a rush though.
#8 ·
Odds on odd, evens on evens no?
#9 ·
I'm not that far North my friend! I'm actually right by lake Ontario. Just like the sound of that better
#10 ·
Just wondering because up north we have no e-test ... yet anyhow.
#11 ·
I'm half way between Hamilton and Toronto. Mine is a personal truck so I can probably just get a mobile guy to come by, it's just a visual. For Commercial, they can be pricks they took a gun to my buddies exhaust.
It used to be south of highway 9 Orangville. There's some areas in cottage country where you have to have it done.because people were using those address for registration.
Big fan of Bob and Doug Mckenzie
#12 ·
ha I've spent most of my life building cottages in and around "cottage country" ... I'm a little north and you're right ... even up here if you plate your truck as commercial then you have to e-test. I wonder how many trees it takes to make up for the exhaust our vehicles pump out ... up here the trees to humans ratio is about a billion to one.
Off topic, I just found the Ontario forum here ... should check it out ... believe there is a meet down your way soon.
Reactions: 007MegaRam
