you may have seen my earlier thread . well, I finally got back home to Colorado where my truck is, and got my truck properly diagnosed by a good diesel mechanic. I was correct that it wasn't the injectors. mechanic found bearing material in the oil filter. he says it's rod bearings (at least), which has been my assumption from the beginning. it has all the signs of rod bearing failure.
mechanic says an "upgraded stock" rebuild with ARP studs and a better cam and crankshaft is $16k. "tow build" for $18k (i'm unclear on the difference, didn't ask for the specs on that). I called some other shops that don't specialize in diesels and got estimates of $8k-$10k for a totally stock rebuild. the good diesel mechanic back in my hometown in south carolina says $8k for a slightly upgraded rebuild, but it would cost me $1500 to get it towed back there.
truck is super clean but from what I can tell it's only worth $15k-$18k running, so putting $8k-$16k into an engine right after I put like $6k into a new front end and wheels and tires seems stupid. I don't need a diesel anymore and TBH i'm ******* sick of this truck and just want to get rid of it in the least expensive way possible.
i've rebuilt motorcycle engines before, but not recently. is it feasible to rebuild it myself? should I just buy a running used engine and swap it in? sell it as it sits?
I'm buying another truck this week but I need to get rid of this dodge in the smartest way possible sooner than later. I'd like to rebuild it for the experience but also I want as much money back out of it as possible.
