cummins conversion in fl
1 reading
5K views 6 replies 6 participants last post by  simplysmn
I have a F350 its my work truck I use for pulling my equipment with its got a pos 6.0 in it I'm tired of put money into its down again. so I'm wanting to put a cummins in it can find all kinds of kits online but can't find no one in the state of FL to do it for me. I'm looking for a good shop that has done this before and has a track record of doing it well. I'm close to Orlando but will tow it to a good shop thats not to far away
No I haven't found anyone yet called one guy told me it would be $15 to 20k . I'll turn into a reef at that much
#7 · (Edited)
It's not going to be Cheap .If it was Everyone would be doing a swap . To Be honest 15,000 isn't that far off for doing a Repower . Destroked.com is a good site or Fordcummin's.com I believe just do a Google search you will find the companies. If you sit down and look at it .figure 5000 for the Motor because they are going to want it to be fresh same thing with a trans , then you have to have the Motor Mount's and trans mount's and all the wiring . then you have to have the Harness redone so it will make all the Gauges work like stock . then you have a shop rate of what $75 or Higher Per Hour . It Add's Up Quick.
