Obvious metal sounds, loose/wobbly fan, locked up all the time.
Then with a scan tool/Edge CTS/Smarty Touch, monitor fan speed.
NOTE: The following test may take up to 15 minutes
to perform.
The engine should be at normal operating temperature.
1. Set the parking brake and verify the transmission
is in park or neutral.
2. Set air conditioner (if equipped) and blower fan to
OFF.
3. Start and allow engine to reach normal operating
temperatures.
4. Stop engine, connect the scan tool and select
appropriate model year and engine option.
5. Check for and correct existing DTC’s
6. Connect pin 1 of the electronically controlled viscous fan drive connector, located at the lower
fan shroud to battery ground.
7. Using the scan tool, verify that DTC 0480 set.
8. Start the engine.
9. Go to the SENSOR screen and observe the fan speed.
10. Run the engine at 2500 rpm.
NOTE: It maybe take 15 minutes before fan speed increases.
11. The fan speed should increase according to the table below.
12. If fan speed does not increase, replace the electronically control viscous fan drive.
ELECTRONICALLY CONTROLLED VISCOUS FAN DRIVE SPEEDS
ENGINE RPM/ FAN RPM (Minumum)
500 /490
1000 / 950
1500 /1420
2000 /1850
2500 /2230
3000 /2440
13. If the fan speed does increase and there is still a concern, refer to the appropriate
