1999 Dodge 2500 automatic.
Within the last 6 months or so I put on 1 Carter lift pump, 2 Delphi lift pumps and one Autozone lift pump , can't remember the name.
From the start the Carter barely put out 10 psi. at idle and down to 5 psi. accelerating.
1st. Delphi was 13 psi. at idle and 10 psi. on acceleration and rock steady at those pressures. That lasted about a week then the pressures dropped to 10 psi and lower with my mechanical fuel pressure gauge fluctuating 5 to 10 psi. eratically.
Second Delphi worked perfectly like the first Delphi but only lasted one day before before the pressure dropped like the first Delphi did and the pressure gauge acted erratically again.
The Autozone pump started out at 13 psi. at Idle Dropping down to 10 psi. on accelerating then the pressure dropped like the Delphi pumps did and the needle became erratic again.
I find it hard to believe 4 lift pumps could be defective.
Could the ECM be putting out over and/or under voltage to the lift pumps?
I made up a pigtail to see the voltage at the pumps with the engine idling and was getting between 12 to 13 volts at different times I checked.
It also seems like colder temperatures the pumps put out lower pressures than at higher air temperatures they put out higher pressures.
