I have a 2012 6.7 Cummins with a H&S Mini Maxx tuner. I have the EGR and DPF deleted, 5” exhaust and a S&B cold air intake.
The boost pressure defueling level is set at 29 psi.
my question is can I safely raise that level because I’m reaching that level with barely even getting on it?
Everyone above is correct... IMO you are running ancient tunes with the H&S... They did allot of good for us when the 6.7's came out, technology advanced, those tunes didn't due to... well....anyways....the early tunes (H&S) as well as others had too much timing and defuel limits set in them... at the time, technology said it was good.. now we know its not...
theses issues caused 6.7 cummins to catch a wrap of floating heads and blowing HG and crazy Drive pressures.... when you listen to real engine builders talk, timing killed these things.... nothing else...
If you want to save money, keep your foot out of it. If you want to "truck" your truck... get better tuning asap.... If you want to "beat" your truck, get better tuning and order a built trans...
