Block Casting Identification
25K views 7 replies 7 participants last post by  afterburn549
I have a 1999 Monaco motor coach with the 5.9 ISB 275 engine. Trying to determine if I have a 53 block I checked at the front left and right sides of the engine and found a large 6 on the left side just above the oil pan, where I understand the casting mark to be. I can find no references to a block casting "6". Can anyone enlighten me to the significance of that number?
#2 ·
Are you certain it is just a 6 ?
The series ran out a while...53,54,55,56 being the last i know if besides the mexican blocks with stamped id's
#3 ·
If you don't see it on the front of the engine near the oil pant you might be able to pull the serial number and call Cummins.
There should be a big wire loom in covering some of it, if you see a large "6", i bet there's a 5 in front of it. Regardless, the 56 blocks don't carry the same concern as the 53.
#5 ·
I checked again and looked all around the lower portion of the block, immediately above the oil pan bolt flange - forward and aft. It is in fact a big (1" tall) number 6. Also found a number series O7624D immediately above the 6. The engine serial # is 45764483. Obviously I don't have a 53 block, but now I am curious as to just what the 6 represents, as well as the number series above the 6.
#8 ·
If you are not leaking water, i would not worry for two reasons-
If it is a 53 block, it must be a good one as has not broke ,
2, - are you going pull a 53 block Just cause it is a 53 block?
Not all of them cracked.
