Best Guess
1K views 5 replies 4 participants last post by  Cummins 1992
give me your best guess on much power you could get out of by doing this. smoke screw fully turned, starwheel dropped to the bottom, full power screw turned all the way(no run away for ex.),advance timing 1/8, 6" stacks, and a K&N cold air intake. BEST GUESS. don't give me stats or corrections...
BEST GUESS
BTW its a 92 250
#2 ·
each truck tunes differantly. 250 to 300 and going through the stock converter maybe 200 to the ground.
#5 ·
does it matter much what kind of power the truck is making if the converter can really only put down 200-250? my sig is filled out and up to date. i did the exhaust, bhaf and timing in one weekend and all i gained was a bit of smoke, lower temps by 50*, and 1 more lb boost. I'm thinking its cause the converter cant load up the engine any more.
I'm guessing i"m a little over 300hp? sound possible?
