Axle wrap really bad!!!!!
1 reading
10K views 18 replies 9 participants last post by  Midnight Smoker
I guys im new to the site and thought i would ask for some advice. I have a 2006 2500 dodge with the 6 speed manual. We put a south bend clutch in a while back and now i have an unbearable axle wrap or shake when i take off or really bad in reverse. I have a leveling springs up front and new shocks all the way around (just took the 5" lift off) its my dd. What options do i have besides trac bars?
Sent from my DROID X2 using Tapatalk 2
#2 ·
Sounds like your new South Bend to me. Mine does it too. It's actually the clutch "chattering" The only way to stop it is to use a smoother engaging clutch.
Sent from my DROID RAZR using Tapatalk 2
#8 ·
It's not really important. I know what youre talking about though, especially when you back up. It's your clutch that causes all that jumping when you take off. Wait until you back up with a load on. It really gets fun then! Lol. :D
#9 ·
I already know! I use my truck every day for work and tow a big enclosed trailer around loaded with gear. Sometimes i have to put the truck in 4L so i can back it up. That helps alot. Or once you get going and can let the clutch out all the way its fine but when you have to go slow and feather it, look out, it sounds like the rearend is coming out. :banghead:
#10 ·
GDP bars helped me significantly but didn't eliminate clutch chatter/axle wrap.
The harsh engagement of the ceramic clutch makes everything rock. The motor and rear axle rock violently when dropping a ceramic clutch.
Initially, I had no traction bars with this clutch and it was a bear to drive. Now with the GDP bars I can either leave from idle for slow starts or slip to 1500 for quick launches with no bucking. Letting out quickly between idle and 1400 rpms results in various amounts of axle/engine wrap.
When my clutch burns up I'll probably go with an organic triple instead of ceramic double for the next go around. It gets frustrating to drive smoothly with passengers. When I'm by myself I could care less.
Reactions: Midnight Smoker
#12 ·
1 more vote for a grabbing clutch. That is the cause.
The clutch is grabbing and throwing short bursts of torque down the line causing the springs to wrap. Traction bars will reduce the axle wrap and increase the shaking that you feel. The traction bars will attempt to keep the springs from twisting during the torque surge so the next weakest area is the tires. If you got grip you got movement.
Starting out in 1st (sucks when empty) versus 2nd gear will reduce the chatter AND wrap because the flywheel and trans spend less time at different speeds; that is why low range works for reducing the problem.
#14 ·
Its your dual disk clutch.
I had the same problem.... correction: I have the same problem.
Backing up the driveway is a real procedure. Slipping the clutch is useless as the whole truck hops and bounces all over. Drivetrain clanging and banging until I push the clutch in.
Just get used to not slipping the clutch. Using low range helps a lot.
#17 ·
No I don't. I could get one after work tonight. In my mind, you would still get wrap with stiffer springs. Plus it would probably ride like chit. Glaciers's bars may be a bit on the pricey side, but they are well built and they take about an hour to bolt on. Real simple.
#18 ·
The gain of the reduced wrap from the stiffer spring will be negated by how much you then hate the way it rides. Ladder bars and motor mounts...
