lol,
This post has some great responses to his/her original question.
Looks to me that the simple answer is the only ones with problems are in Kalifornia.
Here in Pennsylvania, the law for Diesel vehilces is that all are Emmission EXEMPT and do not have to be tested.
It also say's, can not increase the sound over stock exhaust. It also say's that to test the sound level, it must be tested in accordance with FACTORY TESTING of the sound level.
UNINFORCEABLE in PA for Sound level.
Do you know of a Motor Vehilce FACTORY in Pa? I dont.
Ok. Drive on! Here is Pa's law Pay attn to the red part.
§ 175.105. Exhaust systems.
(a) Condition of exhaust system. All components of the exhaust system shall be in safe operating condition as described in § 175.110 (relating to inspection procedure).
(b) Exhaust system requirements. A vehicle specified under this subchapter shall be constructed, equipped, maintained and operated to prevent engine exhaust gases from penetrating and collecting in any part of the vehicle occupied by the driver or a passenger, in addition to the requirements of this title for emission control systems and smoke control for a diesel-powered vehicle.
(1) A vehicle specified under this subchapter shall be equipped with a muffler or other effective noise-suppressing system in good working order and in constant operation. A muffler or exhaust system may not be equipped with a cutout, bypass or similar device, and a muffler may not show evidence of external repair.
(2) The exhaust system of a vehicle may not be modified in a manner which will amplify or increase noise emitted by the motor of a vehicle above the maximum level permitted by Chapter 157 (relating to established sound levels).
(3) Headers and side exhaust are permitted if the vehicle meets the requirements of this section.
(4) An exposed exhaust system shall be equipped with an adequate heat shield or protective system.
(5) An exhaust system shall extend and discharge completely to the outside edge of the vehicle body, including a truck bed, or as originally designed, except for the following:
(i) Heavy trucks or truck tractors. The exhaust system of every heavy truck and truck tractor shall discharge to the atmosphere at a location to the rear of the cab or, if the exhaust projects above the cab, at a location near the rear of the cab.
(ii) Gasoline powered buses, including school buses. The exhaust system of a bus powered by a gasoline engine shall discharge to the atmosphere at or within 6 inches forward of the rearmost part of the bus. Until June 15, 1998, the tailpipe of school buses may extend to, but not beyond the body limits on the left side of the school bus within 60 inches of the left rear wheel as measured from the center of the wheel axis.
(iii) Buses, including school buses, powered by fuels other than gasoline. The exhaust system of a bus using fuels other than gasoline shall discharge to the atmosphere either at or within 15 inches forward of the rearmost part of the vehicle; or to the rear of all doors or windows designed to be opened, except windows designed to be opened solely as emergency exits. Until June 15, 1998, the tailpipe of school buses may extend to, but not beyond the body limits on the left side of the school bus within 60 inches of the left rear wheel as measured from the center of the wheel axis.
(c) Exemption. A firefighting vehicle is exempt from this section.
