SO I am going to do compound turbos on my 1939 truck. I have a 95 12V and will be using the stock HX35W. I found a great place that has tons of turbos from Cat engines, large semi tractor trucks ets. After much research on threads here it seems like the s475 would be a good turbo to use in conjunction to the stocker. Now because I am still new to these things, how do I know what to look for? They have literally thousands of turbos there... I still have not figured out the whole size thing, inducer, wheel, AR ratio... so I need some help on what to look for. Is there a turbo that would work well with the stocker off a semi?
I am only looking to hit about 500HP and going with 50-90 over stock injectors. I know this question is asked over and over, but please help me to know how to identify a good turbo for my truck. I am not afraid of which flange it has because I am fabricating everything anyways.
Also do I need to take the wastegate off the stock turbo, if so what do I need to do, do I have a wastegate??:confused013:
