Hi all:
I'm getting a P0122 code, CEL illuminated. I'm seeing both a pending and a current trouble code, P0122.
My truck is a 2001 MANUAL transmission. Starts/runs/drives normal, no noticeable manifestation of the error code while driving, thankfully.
I used MoparMan's excellent step-by-step guide ("DTC P0122: APP SENSOR SIGNAL VOLTAGE TOO LOW")...
Step 1: PCU P1693 and ECU P0122
Step 2: 5.01v.
Then I got to Step 3, which is "Turn ignition off. Ensure APPS harness connector is still disconnected. Check for continuity between terminal No. 4 (Black/Yellow wire) and terminal No. 5 (Dark Blue/White wire) on APPS harness connector. If continuity does not exist, go to next step. If continuity exists, repair short between Dark Blue/White and Black/Yellow wires. The Black/Yellow wire is the sensor ground circuit."
I AM getting continuity between those two wires...so looks like there may well be a short.
My question is this: IS THERE A TYPICAL LOCATION I CAN BEGIN LOOKING THAT THIS SHORT FREQUENTLY OCCURS?
I figure I'd ask the question here, since a bunch of you guys have had this issue, and I'm sure have located where the short was...rather than me just blindly ripping apart wiring harnesses randomly.
PART 2:
It's a manual transmission truck, so I'm curious if I would benefit from the $30 BD Diesel APPS noise isolation kit mentioned on Geno's site. Is it worthwhile installing it on a manual transmission truck? Thoughts?
Thank you very much,
Kevin
Step 2: 5.01v.
PART 2:
Kevin
