A727 trans rebuild help
3.8K views 31 replies 11 participants last post by  PO-TECH
Hey, I have a 1991 Dodge Power Ram 350 with the A727 3 speed automatic transmission. it also has an external overdrive kit on it from the factory, followed by the transfer case. trans is shot and i want to rebuild it. Can i use any 727 rebuild kit so long as it covers that year, or do i need something special? Any help would be greatly appreciated. Thanks
#7 ·
#9 ·
Thanks, ill check the stickers out when i can, and try to enchance the pictures i have to be able to read everything. when i go home on the weekend, ill check out the trans and see if i can find the data plate for it.
#10 ·
if you are still not 100% certain call dodge or go to a dodge dealer with your vin and they can give you a full report of what your truck was built with. sometimes it costs a few bucks though.
#12 ·
does the truck have a o/d button next to the cargo light button? the engine bay picture looks like a factory intercooled truck.
there might of been a screwup at the factory with the sticker with the change over i've seen that before.
#16 ·
Not that i know of, we got the truck in 95 with aroung 200,000 km on it, pulled the box off a couple years later, coverted it to a duelly and put a mechanics box on it. ran that way for 8 or so years. She pulled loads nearing 20,000 lbs with 2-3 tons of box and tools in it, trans cooler failed causing anti-freeze to get into the ATF and the clutches started to slip on a big load. as close as we can figure there is around 800,000 km on it, odometer stuck in the 200,000's.
there is a o/d button in it in the factory position
WP_000262_zpsa85afc00.jpg Photo by PO-TECH | Photobucket
and here is where she sits, waiting for a spot in our shop to open up
WP_000332_zps8d2bf0d6.jpg Photo by PO-TECH | Photobucket
#19 · (Edited)
From that tag, it looks to me like that's an intercooled 1 ton with a 727 and 4.50 gear?!?! That's gotta be one odd combo, although the 4.50 gear could explain why there is an OD behind the trans. I have no idea why that truck wouldn't have a A518 behind it. Any chance you can get a pic of the back of the trans and / or the OD unit? If you don't have a 518, I'm thinking it's an early Gear Vendors unit. I've never seen one, I know they used them on some bigger Dodge RV's back before the Cummins was used.
#20 ·
i managed to get a couple pictures this afternoon of the trans and the drop box, not the best pics, only had my phone and it was too bright to check the pictures untill after i was back inside a couple hours later. really starting to think its the a518, ill post the pics later
