6.7 injectors help please!!!
1.6K views 16 replies 4 participants last post by  emotter
Notices a little whitish purple smoke coming out of the exhaust on start up when the truck is cold or sets over night. It's summer hear so what could it be?
It don't do it any other timer but on start up.
#2 ·
Has it always done this or did it just start? Sounds like just the general condensation burning off exhaust pipes, or maybe you have a cooler boot leaking a touch and sucking extra air.
its likely not injector problems, they dont often fail on a stock 6.7.. but i guess it always could be given the symptoms. I would do a boost leak test on it first.
#8 ·
fairly simple.. you can buy a boost leak tester or make your own.. its worth a google
#12 ·
did you delete the cooler as well? and if not, is your coolant level moving at all? EGR coolers tend to fail more when the EGR is deleted and not the cooler, and that would cause a coolant leak into the exhaust
#16 ·
it could be the beginning of a injector issue. How frequent is your filter replacement interval.. consider adding additional filteration.. Perhaps some injector cleaner and a hard pull for a few hours.
