Guys, I have an 08 Dodge Cummings that is coding throttle/ pedal position sensor circuit. I have had the computer, fuse block replace by the dealer. 3k later it is coding the same as when I brought it in. I really need help. Anyone have any ideas?
6.7 cummings dodge throttle/pedal position sensor coding
I am no help to you. But you have come to the right place. Someone will be along shortly. And its Cummins. Cummings is at the end of dirty movies!!!!!!!!!!!!arty018:
My truck was just in the shop for three weeks for codes P2121 and P2127 which both dealt with pedal position sensor problem.. Dealer replace my gas pedal assembly and sensor, which didnt solve the problem.. After going back and forth with chrysler they replaced the wiring from the sensor to the next union... So far it seems to be ok.
Truck would buck and shudder.. Gas pedal had a mind of its own.
by any change have you been doing any power-braking?
I used to do this on my 5.9, but the first time I did it on the 6.7 I got this code and figured out it doesn't like me to press on both pedals at the same time
My light just came on this morning also. Throttle position sensor is the code I'm getting. It also said something about a circuit. Never was on last night, started it this morning and it was on :/ kind of in a bind now!
mine was loose wiring harness close to egr gheck all harness clips
Related Threads
Cummins Diesel Forum
posts
9M
members
405K
Since
2005
A forum community dedicated to all things Cummins Diesel! Originally founded for owners and enthusiasts of Cummins powered Dodge pickups, the Cummins Forum has expanded to include ALL Cummins Engine applications! Come join the discussion about reviews, drivetrain swaps, turbos, modifications, classifieds, builds, troubleshooting, maintenance, and more!
