OK - So I've found a couple of similar threads but they are going MUCH further than I am so I thought I'd just ask...
Background Info
I've owned my '06 Cummins 48RE 4X4 for about 96 hours... I wanted a manual but as I said elsewhere I found 3 unicorns, 2 leprecauns, my grandmother's lost wedding ring from 1931 and Jimmy Hoffa but did not come up with a reasonably low mile 5.9 manual trans 4X4 for less than I paid for my first house - so I bought an auto truck. I'll be towing light (for this truck) loads around AZ - can't see myself getting beyond 17K combined unless I win the lottery in which case the 42' Toy Hauler will come with a 4X4 Dually / manual truck...
The truck has 83K original miles, was reasonably well maintained including major maintenance cycles at the dealer where it was purchased. The original owner says that it has never towed more than a few thousand pounds on a single axle trailer - and I see no evidence that it has ever had a 5th wheel or gooseneck ball installed. The truck seems to shift fine (by this I mean that the shifts feel "OK" - not slipping not clunking - probably a bit softer than I'd prefer but they feel "normal") although it sometimes feels almost like a double upshift which I assume is an upshift followed a long fraction of a second later by TC lockup - and I'm guessing is also normal...
Anyway - I've read the horror stories about the 48RE - and I've also read threads with multiple folks stating that they've got more than 250K miles on their stock 48RE's and are still going strong - so I'm going to try to get as much life out of the stocker as possible... At the point that this transmission dies I'll either buy one from (or build one with good parts from) one of the reputable suppliers like Goerand, SunCoast, etc... but I'm not there and don't want to spend that money until I have to. So - as much as I'd love to hear about it - I'm not sure that: "I'd buy a full billet, custom valve body, trans with a 9 clutch billet converter - it'll hold 2200 ft/lbs and I run 9s through mine all day long and with a flip of a switch I can tow my M1A Abrams on an 8 axle low-boy across the continental divide at 75 MPH " does me much good.
I'd love to be there some day - but that's not reality for me today.
SO - The Question...
What PROACTIVE and relatively low cost mods would you do if you were going to be pulling less than 10K lbs behind a stock 5.9 and want to get as many miles / years out of your 48RE as possible? The stuff I'm looking at immediately is the following:
Standard Maintenance
* Fluid Change - Over the last 25 years or so I've determined that it is never a good idea to "power flush" an auto trans. I normally just drop the pan, replace the old filter with a quality unit, replace the pan gasket and re-snug the pan, top the pan off to the "full" mark on the stick, fire the engine and then fill to level... Any reason to do something different with the 48RE?
* Band Adjustment - You know what they say about assumption - but the transmission was "serviced" at the dealer about 20K miles ago - so I would hope that this was done then. Not sure if this is a DIY thing on this one or not. I'm OK doing it with my old school stuff (Ford C6 etc...) Thoughts?
Sensors and Solenoids
I understand that there are a number of sensors and solenoids that fail and when they fail can cause "small" changes that don't demand immediate repair but that shorten the life of the transmission substantially.
* Governor Pressure Sensor (or is it a solenoid? or both?) Would you change this when doing the filter swap? If so would you use OEM or do the B/W conversion?
* Output Shaft Speed Sensor (I've only seen this one mentioned as a "problem part" one time)
Is there any other relatively low cost part that I should change when I'm in there?
Additional Cooling
I've looked at both a supplemental pusher fan and an additional cooling unit with its own fan and I'm leaning towards the pusher fan both because it works and because it does not bring with it the risks of the secondary unit (flow restriction and more stuff to get caught on branches or rocks when out in the woods). I'm hearing from a local friend that the stock trans cooler works very well as long as it has sufficient air-flow. He is running one in a truck very similar to mine and has had good results (spent a couple hours moving very slowly over rough and hilly forest service roads at 22K gross and trans fluid temps stayed at or below 200). Thoughts on this topic? If I'm not going to be pulling 25K lbs around in the sand at Glamis would a pusher fan not suffice? If you've done this what fan have you used and have you been happy with it?
Deep / Finned Aluminum Pan
Some say it is good - some say it is not worth anything... IMHO having a drain plug is a nice thing - and having a couple extra quarts of fluid in there can't hurt things and that the aluminum / finned aluminum pan will dissipate more heat than steel. If the consensus is that this is worth 0.000001% improvement in tranny life - then I guess I can weld a bung in to the stock pan... Thoughts?
Other Stuff?
What am I missing?
Background Info
Additional Cooling
Other Stuff?
What am I missing?
