Hey there everyone, so I've got a rather unusual problem. I've read what seems like every single post I can find on the internet regarding the 48re, but I can't find a single person who has experienced what I'm going through. Hell, I've even managed to dig up the 200 page 48re instruction manual, and I'm still scratching my head. With 225k on the factory tranny, I'm sure a replacement or rebuild is in my near future. But I want to ask here anyway.
So here is my very long winded post, full of detail!
A few weeks ago, I was hauling about 800lbs to a job site, like a retard, I went ahead and left my edge cranked up to setting 5 while I drove about 15 miles. When I got to the site, I dropped it back down to zero since it was a mud pit and I'd need 4wd to get around. Anyway got done drove home everything was fine. That was a Friday. After sitting all weekend, on Monday morning when I left for work, reverse seemed like it was only 1/2 in. Truck was very.... reluctant to move. Shifting in general was very troublesome. Truck wouldn't shift up properly, nor downshift properly. It would act like it was going to shift up, pop out of gear, and then go right back into the same gear it was trying to leave. Very frustrating. Wouldn't shift at all, or take 100 yards of coasting to finally shift.
So I did some research. My fluid levels were fine, but the fluid did smell a little burnt, and was a nice maple syrup color, but there wasn't any clutch material or metal mixed in. I'm also not slipping, even in setting 5 and flooring it the transmission holds the power. So I dropped the pan, which was remarkably clean, except the magnet, it had about a 1/16" of crap on it. I adjusted the bands, changed the filter, put in some fresh fluid. Well... That sort of fixed my problem. The truck drives fine, assuming I manually shift it. If I'm in the D position the truck starts in 3rd. Will not start in 2nd or first unless manually there. If I'm at a stop and manually shift to 1st, and go up through the gears while stopped it will shift them while sitting there, you can actually feel it happening. Shifts from 3rd to 4th fine, a little hesitation every once in a while, and downshifts from 4th to 3rd like one would expect. But will not downshift to from 3rd to 2nd, or from 2nd to 1st. But if I manually downshift, works like a charm.
So now to the confusing part. If I'm at a dead stop, I shift to neutral, and pop it into 1st. Its a pretty harsh engagement. Like I got hit from behind by a prius driving about 10mph. I'll shift to 2nd about 10mph. when in 2nd with out fail every time I get to 25mph the truck acts like its shifting again and its a very quick shift, I drop about 300 rpms, and continue on in 2nd. At about 30 mph, I put in Drive, and it shifts into 3rd. When I hit 45 mph, again the truck acts like its shifting, but doesn't. Drop about 300 rpms and continue on until 50mph, when I press the O/D button and shift into 4th.
In both 2nd and 3rd, before the "shift" the truck feels like its dragging weight. At the 25mph, and 45mph quasi shift points it feels like the truck just suddenly dropped about 1k of weight. Also, depending on how much throttle I'm giving the truck will dictate how the shift feels, meaning if I'm at 30% throttle its feels like a light, or barely noticeable shift. But if i'm giving it some umph and at say 50% throttle, it feels like the train from back to the future 3 cooking off the yellow roll of magic go fast stuff, a nice jolt of "yeah baby lets roll!" And this is with my edge on the stock setting. Obviously the extreme setting only exasperates the issue.
So I'm left scratching my head. It seems like the valve body is probably the problem. And frankly with 35" tires, 225 on the clock, and all the HP i've put on the truck, I'm sure the trans is probably just worn the hell out. However I'd love to hear some theories, or definitive info.
What I find weird is the fact that aside from the odd 2nd and 3rd mystery shift, is the fact that the truck operates perfectly fine if I'm doing it manually. All the diagnostic things I've read seems to indicate that should have lost 1st and 2nd completely. But I've only lost those 2 gears in the D position.
There's probably more info that I'm forgetting but, I'll be checking this often so I'll answer any questions you may have.
Thanks!
Thanks!
