all right guys i need to know how to get an 05 4door 2500 cummins close to 30mpg's.
eelout
all help would be greatly appreciated.
thanks, stroker03
thanks, stroker03
I just hand calculated 37.2 MPG's in my ghetto cruiser.Say it with me.....
H-O-N-D-A
eelout
True, my old 7.3 got a best of 18 or so on the 35's. Overheads are not always right, and hand calculations are about as good as guessing.You are about 8 MPG higher than most I've heard about with a Ford. The Company I work for uses Fords and they get about 16-18 empty and 12-13 towing a tool trailer.
Are you figuring the milage by hand or using the computer?
PS isn't really sluggish unless it's stock. MPG towing are a heck of a lot better than a gasser so what if it's not as good as our Cummins trucks.I have on several occassions got that on my truck. I've driven 3 different PS & not only are they sluggish, but their mpg are horrible when towing on the interstate. Why do I think Stroker was sent over to do some bashing???
I read that too. But I wonder how much time and money he spent on all that crap. Not to mention how stupid it looks. By the time he went through all the time and money he could have just bought a Cummins and got nearly the same.OH, there's actually an article kind of about this in the new Diesel Power Mag. It's about a guy with a PSD that's tryin to make the best fuel economy. He's gotten up to 26 mpg. It's a 2wd 6 speed one ton extended cab. He changed the differential to a 3.08 instead of the 3.73, filled with Amsoil. (60 mph @ 1450 rpm!!!) added a "large aftermarket air filter" (looks like a BHAF), 4" exhaust, "disabled backpressure valve on turbo", added a 203 degree thermostat which puts the engine at warmer temps. (says that itself improved mileage by three quarters of a gallon, whatever that means probably means 3/4 mpg). Replaced all engine coolant with waterless coolant, and a "custom burned chip" that decreases fueling and advances injection timing under 2000 rpm. He lowered the pickup 3" in front and 4" in back and put a big air dam from an excursion on the front and built a big cover to cover the bed and keep air flowing over and not building up. And he put 225's on for the tires. He makes 26 mpg.
