2005 lope at idle (cold) & using coolant
3.3K views 20 replies 9 participants last post by  cumminsdart
Any input guys ive heard it was an injector. and what would be the fix replace all six?
thanks
mine sounds like its loping when i started it this morning in 24 degrees and it went into high idle. also was puttin out some white smoke. then agin its cold and my friends do it as well
#7 ·
Try to leak down test the cooling system hot like you would a Subaru first.
Try to also find an exterior coolant leak and test oil for water and fuel.
A small coolant line roughly 5/8 in behind the turbo often leaks and sometimes looks like oil that it carries from the rear main.
Any smoke? Tiny champagne bubbles in the coolant when you bring the RPM up to about 1500 or so? Making oil/chocolate milk?
Reactions: Subarutek
#9 · (Edited)
No external leaks just bought it used, coolant overflow bottle was empty added a gallon to it i will pressure test it tomorrow at work i ran cetane booster in it this weekend thinking it may be a possible stuck injector seemed to stop loping not as bad as it was hoping the pressure test passes tomorrow thanks for the input if it is an injector i will be upgrading to 50 Horsepower injectors and an intake :drool2:
#10 ·
Pressure tested it today at work found coolant line left side looks like to somesort of cooler it has been replaced before the wrong way with cheap worm clamps, Headed down the street to dodge to order the line or pick it up if its in stock, oh yeah my belt also shredded a rib this morning... got to pay to play
#12 ·
Does my 05 have high idle? and i found a hillbilly repair done by previous owner 5/8" cooler line to the torque converter cooler was leaking properly repair at work today plans for coolant flush and thermostat this weekend thanks for the help fellas
#17 ·
How do you function the manual high idle?
#19 ·
For auto high idle when coolant temp < 200*F:
Ambient temp < 15*F, ramp up to 1000rpm as soon as start the truck.
15*F < Ambient temp < 32*F, ramp up to 1000rpm after 2 minutes idle.
