Hey Guys,
I have a 2006 (Build date June of 06') Cummins 4x4 2500 with 33,xxx miles on it. The truck has 315/70 tires, G56 trans, 3:73 gear, straight exhaust, modified factory airbox with K&N filter, Wilson Thrasher Intake, With a Bully Dog Triple Dog tuner. The truck just does not run or tow like I think it should. With the truck empty, the best I can get MPG is like 16.3 before I even had the Bully Dog on it. I can hook my little 4-wheeler trailer with my wheeler on it (about 2500lbs at most) and my fuel drops down to like 12-13 MPG. This is calculated by hand not using the lieometer. I know my right foot has a lot to do with my MPGs but, I've done this numerous times and come up with the same results.
When I hook even this little trailer to it, I have a hard time trying to pass people on the hghway. Are my tires killing my truck this bad or is this a common result with these trucks? I keep the fuel filter changed on time. Is there anything else that i need to look at? I'm just really disappointed in my Cummins in the power department
My buddies Duramax will run all over me!!
Also, just for info. I put a quadzilla boost fooler on the truck, and the truck will not hardly take off from a dead stop in tow mode. It does a little better in performance mode, but is still real lazy until about 1700-1800 RPMs so I took that off.
Any input would be greatly appreciated!
-Coleman
-Coleman
