I’m not an authority on this swap as I’ve only done mine and many of the parts I bought were gathered up by someone that bailed on his swap.
I will start off by saying there are two different ZF6s. A 650 and 750. Those numbers designate max torque ratings. I cannot remember the break year but I believe it was 03 when the 750 was introduced. Don’t quote me on that.
I will just go through a few things that I do know, I am sure there are other options and routes you can take to achieve the same goal.
I used in my swap a ZF6-750 and a NP271 manual shift. Here is a partial list of parts a guy would need.
Adapter plate (I used a Destroked aluminum one)
Clutch master and slave (Dodge master with a ford slave. Mine came in that box of parts. I was told valair put it together but don’t quote me. I do know that they will mate up.)
Six speed fly wheel (I used a Dodge with a spacer to move it away from the crank and machined a pilot bearing into it to accept the ZF6 input shaft. )
Clutch (I had a new SB in front of my old NV 4500 that I used)
Power stroke starter(goes on passenger side)
Ford throw out bearing and clutch arm, aftermarket trans cooler and lines, tranny mount
I am sure there is more that I am forgetting but we’ll get to it.
There is a reasonable amount of fab work. You have to build a crossmember, work out a transfer case shifter, wire up the starter, rework the drivelines, etc.
I took a lot of care making sure that the attitude and centerline of the trans and transfer case were close to stock. I had to massage the driver side frame rail a little to get the transfer case to fit. I also had to beat on the body for down pipe clearance. Also had to put a small indentation in the downpipe to clear the starter. Had to cut a pretty big hole in the tunnel and make a shift tower cover. Made the transfer case linkage with my old 241 linkage. Had to lengthen it and build a little bracket to attach to the ZF6. One plus was that seeing how the trans/transfer case is approximately 8 inches longer, I could go to one piece rear driveline.
Dakota Digital has a work around off of the abs sensor for the speedo.
I’m sure there is more and you’ll have lots of questions. I’ll do my best to answer them. I can get some pictures at a later date also.
