Ok, I have seen alot of guys asking, "How can I get more boost out of my truck?". So I am doing this little post to help out. Mods, feel free to sticky it if you feel necessary.
Down to business:
How to get more boost. The answer is more fuel.:thumbsup:
These trucks have MAP sensors in the intake manifold. MAP = Manifold Absolute Pressure, in other words, a sensor that reads boost in the intake. SO (standard output) trucks have programming in the ECM that cuts back on the fueling (defuels) when a set amount of boost is seen at the map sensor. This happens at about 20-21 psi. ( a bit higher on the HO-high output trucks).
So, if you put a boost gauge on your stock truck, you will see maximum boost somewhere in the neighborhood of 20 psi.
Besides the stock ECM fueling parameters that keep you from exceeding around 20 psi of boost, there is a wastegate on your turbo. The function of any wastegate is to bleed of excess boost from the turbo. The wastegate has a spring and diaphram inside it that physically moves a rod and plunger in the exhaust housing of the turbo at around 20 psi.
So to get more boost out of your truck you:
A) go buy a "chip". This gives you more fuel. Practically everything on the market these days has a "Boost Fooler" built into it. The "boost fooler" tricks the ECM into thinking that the boost is not exceeding stock limits, so that the ECM won't DEFUEL to try and keep you below 20 psi.
Now, you got your chip with boost fooler, and you crank her up hoping for high boost, but you only get around 24-25 psi. How are all these guys getting 30, 35, 40, 45 psi??? Well, Even though you added more fuel the WASTEGATE on the turbo is still doing its job! Its bleeding off that extra psi you are making to keep things around 20 psi. Which brings us to :
B) You need to get control of the wastegate. This can be done in a few different ways, all achieving the same results. I will focus on the most common. First We need to know what stock turbo you have. The options are HX35 and HY35. If you have an 01 or 02 model automatic trans truck, You have an HY35 turbo. To increase the boost on this turbo you need a "J-hook". This is a hook with a spring that effectively holds your wastegate closed to a certain point, allowing you to make higher boost with that fancy fueling box you bought!
If you have an 98.5-02 manual trans truck, or a 98.5-00 auto trans truck, you will have an HX35 turbo. To increase the boost on these turbos, you need a "Boost Elbow". This replaces the stock elbow coming out of the compressor housing with one with a smaller orfice, OR an adjustable orfice, so you can set the boost level you want. Now you are capable of higher boost on your HX35!
Couple of things to remember:
1) Your boost won't go any higher if you aren't adding more fuel.
2) If you add a "boost elbow" or "j-hook" to your truck, without adding an electronic boost fooling device, you will cause the ECM to DEFUEL! , Giving you the same or less power than before. You will also be throwing P0237 codes (turbo overboost condition).
3) You can run a fueling box without running a boost elbow / j-hook on your turbo. It will work. You just wont be taking full advantage of the extra fuel you are adding, and your EGTs will likely be a little higher than if you had the extra boost.
TST Boost Control
J-Hook Assembly
http://www.tstproducts.com/pdffiles/PMInstr6.pdf Page 3, halfway down page, pics of (left to right) boost elbow on HX35, stock metal boost line on HY35, and HY35 with J hook installed. Also, installation intsructions for boost elbows and J hooks above and below pics!
Hope this helps:thumbsup:
Josh D.
Down to business:
TST Boost Control
J-Hook Assembly
Josh D.
