1 - 4 of 4 Posts
I have an 03 with the 230 horse motor and a 48re and recently the trans does'nt want to shift out of first gear. It does'nt shuttle shift, it just does'nt want to get out of first till im going about 35 mph. Then it will shift normaly through the rest of the gears. Any ideas? Is it in limp mode or???
Do a search for TV cable adjustment. It shifts perfectly normal for all other gears? What about when you are slowing down, does it downshift properly, or does it slam into 1st gear?
TV Cable is a place to start.
Yep it shifts normally once past first and down shifts normally also. will check on the tv adjustment, thanks
1 - 4 of 4 Posts
