Installed a XZT+ a few days ago.. installed the updated agressive tune off the quadzilla website.. For the money it is good cheap power.. I like it..Have yet to test the econ setting
eelout Where are you guys mounting the module in the cab? It says inside the box that it must be mounted in the cab (I assume to keep dirt and moisture out of the unit).
Also.. the switch it comes with is pretty ghetto. I assume I could wire up any ON/OFF/ON toggle switch in place of the little one it comes with as long as I wire it the same?
Thanks!
Thanks!
