The output shaft from my NP going towards the front axle wobbles, and the seal is starting to leak..bearing?..do i need to pull the t-case to fix this problem?:thud:
Are you sure it's the output assembly or is it the CVU joint? Just check it real close. If its the T-case then pull it and go clear through it when you do. It's really not that hard.
yea its the shaft itself, the double u joint assembly is still tight.... welp looks like i'm goin to rebuild it...anyone know where to get the rebuild kit?:thud:
