3rd gen brake upgrade opinion
  • Total voters
    64
141 - 146 of 146 Posts
This is actually a cheap and easy mod...
Napa has cardone calipers (3rd gen years, for $55), they come with the brackets
Grab 3rd gen rotors and pads...
Bolt them on and roll.
The 3rd gen calipers i bought are still in the box....i just used the brackets, rotos and pads...
autozone sells just the brackets, i think they were about $28
I got my brackets just need rotors and pads. What 3rd Gen rotors and pads are you guys using?
When i say 3rd gen, i usually ask for 06. Middle ground and all.should be uniform at that year.
1994-1999 use parallel ball joints. 2000-2002 use opposing ball joint angles.
Has anybody figured out why they changed to that design??? Does it give better return to center characteristics or what?
If all parts are in order ..it should.
Think shopping cart...bad wobble when not right. That is deathwobble.
So I did this when I bought the truck back in 2013. I have put 130,000 miles on these brakes and have only lost 2% rotor surface and still on the same brake pads. NAPA Premiums Just going to say best thing ever.
