Well the other day I went off road and put the truck in 4wd high. Moved forward about 50 feet and the shifter popped out and back into 2wd. This will happen when engaging 4wd from a stop or rolling. Any suggestions? :confused013:
Thanks!
Trying to learn
'03 QCLB 2500 305/555 NV5600 3.73 4x4
Check the linkage on the 4x shifter, make sure it is going all the way into 4x.
West Virginia Chapter VP
Pull up your shiftboot and see if anything has lodged
there from your drink holder! I had a pen and a penny causing me the same problem
Will take a look tomorrow.. Thanks guys
If that doesn't help I had the opposite problem wouldnt stay in 2wd and would go into neutral. Ended up being the main front bearing and the shift fork.
