1 - 4 of 4 Posts
The grid heaters shouldn't come on at all above, I believe, 57 degrees F... very curious how nice it is up there :D
Reactions: CHarrison9612v
12valve should start right away regardless of grids/ no grids or advanced timing . ( with in reason ) .
Check filters , Fuel shut off solenoid and especially fuel pressure / fuel pump .
IF you have to prime the fuel pump via the lil rubber pumper ( say more than 2 pumps ) , air is entering the fuel loop somewhere
1 - 4 of 4 Posts
