ive got a 2008 3500 with just over 35000. its got an edge and the dpf and egr got stolen. the pickup will idle for a couple minutes when cold, then just die. it will fire every time but it wont idle. had a new flash put in a couple weeks ago that didnt work. also get a map sensor code once in a while. any help would be great
go back and check all of your connections on the edge where you hooked to the motor you may not have your MAP sensor plugged all the way together..... just a thought:confused013:
TECH SPECIALIST
remove the edge and see if the truck will start and run just to rule out the edge. It will not have power with the deletes but it should idle fine.
:ditto:
I had a similar problem with mine it would start and idle but when i would give it fuel it would rattle like crazy and die i unplugged the edge and it fired right up. Re-installed it and it ran fine after that.
taking out the edge didnt work. had it towed to the dealership today. the service dude said its a throttle valve???? supposed to be fixed tomorrow
