Hi all,
I have a persistent question regarding wmo and would like some thoughts.
I have a seat Ibiza runing wmo. The old model, European 1900D non Turbo 10.000Km on wmo and counting.
At first I had a lot of problems regarding filters, i once broke up an injection pump, blocked filters all the time, etc.
I've then bought some one micron filter bags and since then no more big problems, stock filter already make about 3500Km.
The strange thing: I run wmo at a concentration of 66 to 33 diesel. The car works well, but each time I add nmore diesel the car starts smoking like crazy! What could this be the problem? Seems to smoke more with a high diesel and low oil concentration that with a high oil and low diesel mix. Could this be that the diesel fires first and the oil in last, not burning ok and with more oil the oil burns more even?
Last few days I start running 100% WMO. Engine starts just fine, runs Ok since I don't pull for it, If I step the accelerator or pass the 80-90kph it starts loosing power, seems like the pump doesent pull the oil, because it's to viscous.
The big problem: Lots of carbon: I have to clean the injectors once about 500Km if only on oil or about 2000-3000Km on a 60% mix otherwise it will stop starting because of the carbon. More, the glow plugs just go bad and burn all the time. I now only turn them on to start the car and then shut them off to avoid them to burn.
Is there any way to remove all this carbon junk? I've heard of steam as a way of cleaning up this, does anyone have an idea?
:shock:
:shock:
