1 - 3 of 3 Posts
On my 97 Dodge with a 7 prong connector. How are the reverse lights connected. Do they run with the same wires as the turn signals and brake lights? What are the auxilary lgihts? The marker lights. And how is it that my turn signals and hazards work but not my brake lights since they all are ran off the same wire. Thanks
Discussion Starter · #2 ·
bump i need some help please
08 Cummins
The backup lights run through the center pin if they are wired into the plug. The center pin is used for some auxilary circuit, backup lights or may not be used at all on your truck. I'm not sure how Dodge wired them from the factory.
The turn/brake signals run through the same wires but they are fed from different sources up front. If the brake lights are not working I would suspect a problem with them up front. Have you checked all of your fuses?
1 - 3 of 3 Posts
