1 - 10 of 10 Posts
Weird Steering issue
The last few days, my truck feels like it is in 4WD while turning. It is not in 4WD
Anyone have any ideas?
Front universal joint/s bad.
My truck started doing the same thing. Feels like it is in 4WD when turning. When parked I can turn to the right fine but it is hard to turn the wheels left.
Any input would be helpful. Thanks
It only gets better
I think you must be right about the U joints. The problem was getting worse every time I drove it, until... It rained! Then it went away. All I can figure is the water lubricated the bad joint enough to settle it down.
The problem did not seem to be different regardless of direction.
Reactions: mdtouchet
Front drive shaft or axle U joints?
Its your front axle u-joints worn out. They get worn and cause that binding feeling you get in 4WD.
Is there ant=y to find out which one, or should I get both replaced?
If you get under the truck and grab the u-joint where it comes out of the axle you can probably wiggle it, or feel some slack. Might make a clunking noise if its real loose. Thats pretty well the best way I've been able to tell. If your mileage is high enough on the truck you could always ask to have them both changed while they are in there. I would recommend getting them to install greasable Spicer made u-joints as well so that you can maintain them
$850 - dealership replaced both u joints and the problem is now fixed.
1 - 10 of 10 Posts
