1 - 2 of 2 Posts
:confused013:so this might be a really dumb ? but id rather look like an idiot than not know. when everyone talks about the wire tap on a vp 44 truck are they just talking about the wire that comes off your chip such as the edge comp or juice that hooks up on the wire on the pump or is there some other trick im still in the dark about:confused013:
I would have to say that, you are currect. Both Edge Comp and J/A have the wire tap to the VP44 pump. Some use wire connectors some use the STEALTH cover. The stealth cover is the best way. Due to the fact that a tapered screw is used to puncher into the wire of the VP444 vs a wire connector. The wire connector can cut the wire tap of the VP44 in to. Then your in deep ca-ca.
GOOD QUESTION THOUGH. :headbang:
FYI
1 - 2 of 2 Posts
