Does anyone else's windshield washer nozzles suck? Mine barely squirt out any fluid. I took them out and cleaned them and they work even worse now.
Any solutions to this?
Bad pump or bad nozzles!
The only way to clean them is blowing with compressed air from the nozzle end using any kind of wire will mess them up.
Truck Parts and Truck Accessories
LMC Truck has replacements for $19.95 ea. I would check dealer, might be about the same.
Sounds to me like you need a new pump to solve the low pressure problem you are having.
:flag:
I've heard that soaking them in vinegar will dissolve any crud like lime thats built up in the holes. Never tried it though so I don't know if it works.
