Well...there's not much to it. Buy or make yourself a receiver hitch winch mount. Run a large gauge welding cable from your battery, through a breaker, back to the bumper and attach it to your winch. Ground to one of your hitch bolts. Done.
almost all the MAIN brand winch makers MAKE and sell mounts for receiver's
WARN, Super winch, and likes
I would just BUY one of there's
and I personally would buy the quick plug set up and buy GOOD one's at that
not sure what you need a winch for, but if its to move a STUCK truck, I'd be buying at least a 12,000 lb er!
Rule for winch size is 1.5 x your vehicle weight on single line pull. Remember, when your stuck its not just your vehicle your pulling as a rolling load. Its all the crap/obstacles holding it down. Go with a 16.5k winch from a reputable manufacturer ( I like Superwinch, but Warn and Ramsey also make great products), this will make future servicing much easier.
Couple pointers from a long time Jeeper
1. Synthetic cable is awesome, easier to use, lighter and safer. Downside is it is many times more expensive, requires regular cleaning, should be covered from direct sunlight when not in use and must be replaced every few years.
2. Don't skimp on your power cables. As mentioned above, use a breaker, or better yet buy a ready made kit designed for the load.
3. You can drain your battery while your truck is running!
4. Learn how to do maintenance on your winch, especially the brake, having that fail when your line is holding a load can kill someone.
5. If you use steel cable, be sure to stretch it before first use and grease it regularly to help longevity.
6. DONT USE HOOKS!
7. Spend some money on a good winch equipment kit or build your own. D-ring shackles, snatch block, tree saver, gloves, etc.
8. Don't shock load a winch, they make snatch straps for a reason.
You looking for a front mount or mounting to rear receiver. I would like to add a front receiver but can't seem to find one rated for more than 9k straight line pull.
